- 350 or 500 cfm?
- need timing help
- Valve Seal Replacement
- ticky tap tap the wifes not happy
- emissions/economy build
- overheated
- 400 for mud???
- Vacuum hoses on 351M
- How about this cam???
- timing or carb
- 400 Heads Max RPM???
- Aluminum vs cast iron intake manifold for 400
- Mileage Cam
- what kind of horsepower/torque do i have?
- Great, now I get to learn all about Clevelands..
- oil pressure/ performance
- Main bearing replacement questions
- new cam old motor
- disributer question on 351
- Identifying 400 pistons
- 400 rod max RPM??
- Is my 351M destroyed?
- 351M rebuild opinions/advice
- Should I?
- sencers on old ford
- Tube ..on emissions system
- C block/M head compatibility?
- oil pressure, Ignition, and vacumm ports
- hard warm start
- first ford
