- 400 cid .040 over
- 351m
- pinging
- 400 flywheel
- '78 400
- headers
- heads question
- vacuum gauge reading
- George
- 400 Valve Train Troubles (Bent some pushrods, 5k on motor)
- MSD Ignition on 351m
- Valve covers
- New 400 long block?
- Rebuilt 400 is a Torque Monster!!
- Got a vibration
- Have a motor, not sure what it is
- egr vacuum line routing
- Dumb Mistake
- oil pressure gauge
- checking for bearing size
- Rear Main Oil Leak 351M, any easy fix
- What do you think, should i rebuild the carb?
- Gas Mileage of 400 cu.in. engine
- DUI Distributor/Air Cleaner Clearance?
- The 400 lives! Now I have a few questions...
- 78 f150 ranger xlt 400ci
- pesky distributor
- Smoke comming from the pipe comming from the exhaust manifold.
- Vacume leak
- 71 400 piston
