- intake gasket help!
- headers and everything else
- one beat 351m
- barry grant carb
- lost power through c6
- Best carb for the job!!!
- roller pushrod length???
- decking causing questions
- Sending units.
- firing order for a 400m
- 500+ hp?
- Matt, with 351C from "down under"
- 351c vrs 351m
- Mushrooming Comp Cams pushrods.
- Removing the #4 cylinder exhaust pushrod
- best compression
- low rpm knocking
- weiand for 351 m with egr? Carter afb?
- 351m, no power?
- Looking for 400hp & more torque
- knock under load
- rebuilt 400 quits running
- 400 out, 351m is in
- Performance carbs? and headers?
- What engine do i have
- Want to get my block painted...how much
- help oil bypass
- Timing change without egr?
- egr question
- project 94 f-150 w/ 400 is done
