- A problem with the electrical system..
- alcohol in gas
- Block?
- 79 ford 400
- Sept./Oct. sales flyer
- Power Steering Bracket I.D.?
- Different fan pulley sizes
- tranny for a 351M
- 79 f250 351 won't idle; help.
- Curiosity, compression readings....
- rpms/idle for 400 4bbl
- 400 oil pressure??
- A question about 400M engines..
- 351m/c/400 hedman full length ceramic headers
- Cleveland or not
- 4Bolt Main Caps for 400
- 400 engine build up for Brad
- 400M Flexplate Question
- My nightmare
- Need head gasket rec. for performance 400 build
- Cam Thrust Plate Bolts
- which cam?
- My 400 Build
- Which series valve covers will fit my 351M???
- springless valves fwiw
- Valve Cover Issues
- 265DEH Comp?
- recurving the dist.
- Intake manifold assembly questions??
- block plate question
