- 351 modified?
- Distributor For 400 build
- I got a 400 to build- ???
- Rod to Crank Side Clearances
- 1st Rebuild-- Piston ring offset
- Rotating Assembly
- More power same mileage?
- Heater Hose Water Inlet
- vac advance??
- 351c build up like no other (to drool over...)
- 351M-400 What do i need to do?
- timing 351 m
- Wieand vs Edelbrock intake for a 400...
- 80 psi oil presure
- could i get 20 mpgs?
- I need a motor tech
- Headers 101
- Holley 670cfm Street Avenger -- Bolt on and go??
- not much oil in filter
- cam spec
- intake manifold bolts
- old faithfull during cam breakin
- Any ideas on what my timing should be??
- Help!! Motor will fire, but won't run! New install!
- valve covers
- knock/ping/marbles- Help me,any ideas?
- Rear Main Seal
- sensors not working!
- porting clevo heads
- 400 stroker pistons
