- 1971 351c 4v
- Trouble Identifying an engine
- Need help again.
- Can I make a 351m to a true 400
- What needs to be done to the heads?
- Duraspark Adjustable Vacuum Advance
- firing order
- 434 Video
- Dead 400?
- 400 crankshaft questions
- cam for a 400
- Water leak on '78 400 left head
- Oil Pump Pickup
- CAL cams camshaft
- EGR valve on 400
- Swapping cams
- 400 Pinging
- gapless ring drawbacks?
- head work?
- 351C Rebuild
- Vac diagram 78 400
- separateing flex plate and torque converter ?
- Decided to use 2v heads, cam change :)
- stock valve springs with a 255deh cam
- 400 backfire problem
- 78 F250 400 fould plug
- 351C or 351W
- Has anyone posted a 400 build list?
- recurving a stock distributor
- 351M Timing chain cover
