- Popping through carb
- Another intake question, this time a different one
- Power Steering pump bracket?
- 400 heads on a 460
- building a 400
- heater hose nipple
- engine options...what to do?
- Serpentine pulley from stock Ford parts for a 351C/ 351M/400??
- Interesting engine weight comparo
- another rpm for 351m thread
- 1979 351modified build
- 351M/400 block---Windsor heads
- Exhaust manifold leak-possible damage ?
- valley pan..timing gear..?'s
- vac. adv.
- 400 HP and Torque?
- Just Tore apart 400 Questions
- My 434 Has Arrived!
- exhaust plug in head
- 351c Timing Chain Play
- rpm\400
- Help noise in intake after carb spacer put on
- scored while helping clean a garage.
- actually putting pcv's on
- Tell me about my 400 . . .
- propane conversion piston
- 351c MOTOR MOUNTS
- Engine Block Code
- Thanks to Tim
- valve covers
