- 400 timing cover
- will 351m heads fit a 351w???
- 300 to 400 questions
- truck doesn't deserve the motor
- engine info
- another 351m loosing oil psi
- Crane 272 H10 Camshaft Opinions
- anti-freeze in oil pan
- Do i need the Smog Bs on my 400?
- Recommendations for 351M carb and intake
- an aluminum Cleveland was cast today
- 1979 400 engine leaking air
- 351M carb Q
- Anyone have a vaccuum diagram for 81...
- TMI highlighted on fordmuscle.com
- cylinder numbers
- Transmission options for our fav. engine
- Need Help with 400 block date code
- Another nice Ford truck article
- Need help identifying engine
- Uh oh-Do I need to get different Heads?
- TMI's first 400 Build.
- building a 400
- edelbrock heads
- how bad did i screw up?
- is it a 351m or a 400??????
- '70 351C needs a heavy duty OD Automatic
- charging system diagram
- pump to carb fuel line
- Edelbrock 2171Pk
