- truck backfires and stumples below 2000 rpm
- Best heads for these engines
- 2V vs. 4V heads
- Truck stumbles off idle
- 1000 Thanks!!!
- Camshaft/Spring problem
- Identify this engine? Pic provided.
- wrist pin bushing
- valve etem seals
- Fuel pump
- stock specs.
- 351M runs, BUT........
- Which intake? (cleveland)
- help with emissions
- Help with emissions, first post not working
- Suggestions for passing emissions
- chewed up dizzy again?! Why does it run like crap, and why did it just die?
- Want to upgrade my 351M
- header question
- Looking for low-buck HP mods
- 351m built to a 400
- heads had .030 shaved...what's my new compression ratio?
- Crane cams went under
- carb cfm and hp question
- auto to man tranny swap
- Just bought
- No compression on 2nd and 6th cylinder on 351W
- Oil pressure sending unit location?
- engine problem
- My 400 smokes like a fog machine at a rave
