- Balanced Crank Flexplate Problem
- Is a remote oil filter necessary in a 1979 F250 with a 460?
- Building Efficient 460
- D0VE heads on a stock 79 460
- D0VE-C vs D3VE
- head Id
- vibration dampers
- 1990 E4OD to 5spd swap???
- 460 vs 462
- rear main seal change...leak
- Mid 80s 460 Valve Timing Set Change
- oil pressure question?
- 460 balanced
- ruff and hot...
- blocking oil passages
- Cams Cams Cams
- Another Oil Pressure Problem
- Mallory Distributor I.D.
- External Coolant Leak
- Need some Help
- lifter question
- flywheel
- fly-cut pistons
- 1979 F250 4wd, 460 motor swap info needed
- 460 Blowby - low compression in #7 - Just rings?
- EFI head rocker pedestals
- 460 into '91 F-150???
- PROBLEM Need Some help.
- plate between block and tranny
- Oil Pressure Fluctuations, Help?
