- Finally broke in the lifters
- engine mounts
- pmiming oil pump
- 429 running on 4 cylinders
- 429 Maximum Cam Lift
- Porting & Polishing Myths
- 429 vs. 390GT, what would you choose?
- 1997 ford 460
- Help with Check Engine light
- what year is it?
- Help Needed locating Stock Specs
- 460 Exhaust manifolds
- 500 hp 460
- EFI fast idle
- transmission interchangefrom ? to 460
- 460 Weight?
- 429 or 460?
- HV oil pump and distributor gear carnage
- Performance 460 F350
- Detonation noise?
- kb pistons and hbeam rods
- 89 460 F250 Carb and Intake combo ideas?
- 1997 460 Motor
- 460 street build
- F350 dually project - 460, Thorleys and more...
- Can you waterproof a starter?
- what to expect from 72 429
- 500 stroker hp and tourq help
- 460 Timimg Marks
- sudden power loss, rough running
