- oil cooler factory
- '96 f250 crew cab for towing?? perf. upgrades?
- Valve Repair
- 1996 Ford 460 Exhaust Manifold Problem! Solution?
- 472 on propane!
- Pro-Comp Alloy 460ci Heads
- I want a 460...badly!
- Oil pan swap?
- 1997 7.5 cylinder compression numbers
- Can I change the timing set on a 460 without dropping the pan?
- sheared cam gear 460
- need history and 460 info for a 460 swap, what came in what year??
- 460 front of motor set up
- cant get the new 429 running right
- 460 losing oil pressure
- Engine balancing for a 460 w/ 360/390 flywheel
- Short block 460 oil leak
- St.Louis area question?
- my truck loses power going up hills and smokes
- '88 1 ton dump
- I need help, remote location and no mechanic
- problem with 429 coils blowing
- 460 timing chain am I doing it right
- 460ci CAST HEADS ?
- 545 exhaust manifold issues
- iron head capability
- Need pictures of alt and ps bracket location on 80-86
- power estimation
- Exhaust port shapes
- 460, click, click, click?
