- 460 headers
- Won't crank hot?
- Damaged fuel rail
- fuel injector o ring question
- 460 exhaust leak fix
- Anything I should consider when disconnecting the EGR?
- smoke
- need some fancy aluminum or chrome covers for a 91 fuel injected 460
- fuel pressure question
- 460 Skip Problem..
- 460 to 370
- 370 4valve Lima?
- 460 replacement in a 79 F350 Camper Special
- Will a 88-97 head gasket work w/1985
- Stock '85 C/R?
- 460 From Mercury Colony Park
- new exhaust
- 79' 460..need help with fuel filter
- Power guestimits 521
- 1969 t bird heads
- Optimal timming gear position?
- Camshaft choice
- Differences in 460s over the years
- im lost for ideas
- air pump lines to the the heads
- Best 460
- What weight oil do you run?
- 460 Timing
- How do I ID what year a 460 block is from casting #'s? (bronco 460 swap q's)
- Head cc
