- 460 mods?
- 460 initial start up = super rich exhaust & bad trans leak
- duraspark dist mod
- 1983 F-600 370--have some questions
- 460 Cam choice
- How bad is rust on the 1994 F350 supercab 7.5L
- 460 engine spec's
- 460 timing problem
- Rebuilt 460 w/ mild mods from stock...need a little help
- cooling question???
- ProComp Aluminum Heads on Ebay
- 557ci Cam Range ?????
- No oil pressure, but oil is moving.
- Oil Pressure
- Carb Frustrations
- 460 mpg?
- 460 motor help
- Which compression for 557ci ???
- Custom fit BBK tb and Mustang cai
- inherant 460 problems?
- '70 Lincoln 460 - any good?
- 429 with a ZF
- Any one know the proper pressure?
- 450Hp 460
- Motor Oil
- 460 front crank counterweight with trigger wheel
- 97 460 banks power pack worth the $$$?
- High underhood temps = running poor
- 1997 F350 "check engine" light
- used F250 or F350 for hauling horses
