- 460 pics
- how much vaccum?
- anyone ever use RTV to put a 460 together instead of gasket set?
- Thermactor ports
- tricks to remove stubborn vibration damper key from crankshaft?
- 460 build
- 460...stats?
- '94 460 efi on engine stand - oil from exhaust port - from where?
- is my head gasket blown?
- 5w30 ok for 460 in winter
- EFI 460 for my F150
- HIGH OCTANE FUEL with 11-1 compression.
- 429 specs
- hp torque specs
- Transmission vs MPG
- wanted dual quad intake
- One More Question About Camshaft Indexing
- Victor Intake
- 429 water pump question
- i have searched to no avail!
- Hard vacuum lines
- Better MPG at 75 than 55??
- Broken Spark Plug
- Cracked exhaust manifold
- 460 pulling motor
- 460 heater line
- How bad is a dent in the ignition coil?
- stock 460 cam specs
- 460 exhaust manifold
- 429 - Whatever you can tell me
