- help! 37TE heads for F3TE heads
- HELP NEEDED... 460, 1993 head vs 1989 head
- Best EEC-IV for 460 SD EFI
- Who has blocked off thier heat risers?
- Mid throttle detonation
- 460 runs rough
- Engine build math
- Block plate
- Strange oil pressure loss after cam change
- 429 PI versions?
- 460 motor mounts
- Burning oil suddenly?
- differences between 88 and 97 460s?
- Oil pan ?
- Piston choice 460
- odd 460 engine stumble
- bearing question??
- 1973 429 problems
- Motor Oil Choices for Flat Tappit Engines
- headers fit?
- First time engine builder
- 73 lincoln 460
- opinions on this stroker kit
- Did the 460 ever get roller lifters?
- No timing marks on 460 vibration damper
- 460 pics
- how much vaccum?
- anyone ever use RTV to put a 460 together instead of gasket set?
- Thermactor ports
