- stock hp & torque
- 1996 Ford F250 460 Problems, advice needed
- need some advice with a 95' 460 efi 4x4 f-250
- Frost plug leak
- Wierd Fuel delivery Problem
- running rich?
- Need carb and cam for 545
- 460 Torque Numbers
- 460 boat motor Forged Crank??
- 74' 460 pulley?
- 351M...distributor not turning...pump locked?
- frozen distributor
- Smog Equipment
- Oil Pump Pickup for a rear sump pan?
- Air Pump and Hose Diagrams - NEED HELP!
- Kenne Bell S/C for 460?
- Not Grounding?
- 460 block question
- compression
- Ebay Procomp heads
- Getting a temp. sender to seal.
- 460 eng. question
- 385 series big block 6.1 litre
- Can I use 460 Pistons with a 429 Crankshaft?
- Exhaust Manifolds
- 460 stumble
- Motor runs hot, low power
- need help identifing a smog piece for a 79 f-250
- Good enough fuel pump?
- Oil pump time bomb?
