- Will oil pump fit?
- 78 460 w/ 94 460 EFI
- Belt routing for 460
- Engine Install delay!!!
- 429 thunder jet
- flywheel rubbing on bellhousing?
- 429/460 MT Flywheel Toothcount?!
- 1993 460 check engine light
- High idle
- EFI pistons in a '78 block
- Rust in Cylinders
- 1996 F250 exhaust system question?
- new pull motor for f350
- Overdrive Light Flashing?
- Help changing belts on 460.
- Big truck 5 speed in F-250
- 460 oil pressure question.
- cam and intake question
- Is head gasket right?
- Number of bolts holding tranny to engine block?
- Carburator size?
- 1994 460 vacuum devices on coil bracket???
- 1996 460 fuel encomy upgrades!!!!
- sparkplug threads
- 3 Circuit Dominator Carb....
- Stripped out oil drain plug in 460
- 385 series books
- 89 460 EFI hesitation when accelerating
- 460 Worth it
- 285,000 Miles on a 460
