- 460 for my pulling truck
- Hydraulic Roller lifters/cam
- E350 Bus with a 460
- Looking for a compression ratio.
- C8VE-E Heads any info would help
- power steering bracket
- What is the best block to use to build 514
- 429 CJ Intake -vs- Edelbrock Performer
- Talking about the factory 429 scj intake
- another bellhousing question
- Cam choice and CC question
- 460 Crank Swap
- 1991 460 Won't Idle, Help?
- Biggest cam for stock 460?
- flywheel,will a 390 work?
- spark plug heat range
- Chrome valve covers? (scratches)
- Best Deal, On a 4 core "Desert Cooler Radiator for 1977 Highboy
- Methods of advancing the cam timing
- 460 Smoking upon startup
- '95 F350 7.5L/460 c.i. no good?
- Problems with my timing? Carb backfires on occassion?
- 1988 Ford E350 Van/Bus
- Stock intake
- need help finding a flywheel
- 460 crank in a 429
- D0OA-E?? Rods
- Aftermarket Programmable EFI on a 460?
- Dual Quad Intakes for 460s?
- need some of your input on this
