- 429 Efi
- HELP!79' f-150 4spd 351M to 460 swap
- D3VE-A2A Max Hp
- 370 CID Vacuum Hose Routing
- exhaust reversion dam question
- 460 stroker big but not to big.
- Tunnel Ram Distibuter Clearance?
- Hardened Exh. Seats
- EFI cam question
- 460 or 429 what?
- Front covers and Dizzy's
- Rebuilding 68 460..ANy help
- 460 EFI check engine light
- Whats the best 460 to look for???
- 460 to a C-6
- Fixing Excessive Cam Shaft endplay
- 429 Building
- jacobs ignition
- water pump bolts
- Which cam??
- Exhaust Kit 1990 F250 460 Dual Inlet
- 429 water pump bolts
- 400 versus 460 flywheel help?
- newbie ?'s about motors
- hp 460 ?????
- 460/370? Crank #'s or other ID?
- mercury and lincoln heads?
- Anyone interrested! D0VE-A Block
- Porting Questions
- 429 Specs.
