- Timing chain replacement?
- compression ratio /help
- timing gears
- 460 vs V-10
- 78 460 to 90s 5 speed
- Engine Kit?
- good combo?
- PCV w/ 2 Ports??????
- cam vs California
- 460 injector on time?
- Best EFI 460 ignition?
- 460 mounting
- Forgot to get heads machined for guide plates--do I need ajustable rockers?
- 460 carb milage?
- common cracks?
- 460 EFI or Carb
- Grrrr... Need timing cover
- SD to Mass air conversion
- 460/390 flywheel
- Timing, What about Timing?
- Oil Breather - Help
- Damper Spacer for '86 460
- Speed density
- a lean condition?
- AOD to 460
- offenhauser 360 turbo-thrust
- 73 460 & 89 460 Oil Filter Fittings
- EFI heads
- Are headers worth the money?
- 15 MPG with a 460?
