- mercury marquis 460?
- Almost there
- 460 Rebuild Help?
- 460 flywheel with blow-proof bellhousing, need help!!!
- Here she is!
- Cracked 68 Lincoln Block..Weld it?
- Help with Dove Heads
- COMP CAM, 71 DECK & DOVE HEAD help
- How do I ident a 460 in a Van.
- Has anyone used ROL brand gaskets on their engines?
- Will stock auto trans kick down rod work on a Edelbrock Perfomer intake?
- exaust manifold bolts
- 76 F100 460 oil pan swap?
- Id - Dive-6015-a2b
- Edel Streetmaster Questions
- d2ve heads, good/bad
- 460 Misses Only When Warming
- 460 runs on 6 cyls.
- 2 460's for $200 bucks
- AOD behind a big block
- intake manifold water ports missing?
- 460 intake manifold seals
- desktop dyno question
- Dumb question...460/400?
- 460 start problem
- More 429 problems
- Eagle stroker crank
- Rod and piston #s mean what?
- ignition module
- Overheat caused by DOVE heads? x3
