- 9.5:1 Extreme Energy 4x4
- 460 motor manual
- crank numbers?
- 460 puking
- Any one using a Summit cam, Part #SUM-K3500 in your 460?
- DOVE A2A heads with peanut plug?
- identify a motor
- need some help with a oil relocation kit.
- casting #s on head? 69 T-bird engine
- dove heads
- 1978 Lincoln heads
- What top radiator hose to use?
- Help picking rebuild parts please
- coolant sending unit?
- 92 F-250 460...Milage(gas)
- missing @an idle
- 460 timing
- setting adjustable rockers?
- 460 performance setup
- Does exhaust have to come out to do rear seal?
- The most furocious engine?
- Motor Shopping
- Piston Emergency
- 97 460 info
- This sound plausible?
- Identifying casting #s
- casting #s
- 500 ft lbs@2000 RPM's?
- Exhaust Manifold
- Do i have the desirable heads?
