- Buying a 460 on Sat. morning
- 385 Series Heads
- Building a 460
- I drink way to much gas
- Need some help guys
- Swapping in a 460 in my 79 f350 4x4
- alternator
- 460 towing mods
- clutch and flywheel problems
- Pushrod length checking
- bad oil habit
- 4k-5k stumble and plugwire choice
- 97 460 backfire
- 1986 F800 429 4V Carb!?
- Looking to get a new carb for my 460
- Engine swap options, please
- Another 460 exhaust manifold problem
- What's the thing on the coil?
- E8TE-DA 460 heads
- Will a high volume oil pump fit under a rear sump pan?
- Need 97 460 Advice
- 429 In my 89 Bus
- Speed Density Limits
- '70 429/NP435 build - what flywheel/clutch kit?
- hot fuel option
- that stock monster cat convertor
- 97 460 needs cheap power
- distributor stuck
- What v8 is this
- 460 in need of help
