- Building a 521 Stroker
- Engine question(s)
- help cam gear sheared off
- how do i pass deq? 77 f-250 460
- Idle problem
- 460 Heater hose connection
- Factory 460 Roller cam?
- 460 issues
- L&L Headers
- 205 Thermostat is it Safe?
- Carburetor
- Heat Cross-over??
- how to track down the serial numbers?
- Heavy Duty Alt.
- compression/shaved heads
- Engine Firing Order
- Need a 460 in FL or SE
- Air Injection Manifold?
- Compression ratio for 460
- Oil dip stick, is it reading correctly?
- Building a 460.
- railrockers and .540" valve lift?
- Are they the same?
- trouble codes
- 460 timing marks, which one?
- Found a 73 429, what have I got?
- distributor question
- 460 tack
- Going through starters left and right
- Changing cam bearings
