- How many cfm is the stock holley on a 84 460 ?
- 89 460 exhaust ?
- how much bore 1971 429
- List # for 87 e350 460 holley carb?
- f350 no start
- A word of caution.....
- still no 429 info
- 1987 460 holley carb fuel leak!!! :(
- 460 issues
- Trick Flow street heads
- help with a distributor in a 460
- Bad mileage, Mass airflow?
- what plug (not brand) in modified 460?
- 351 out 429 in
- 429 info
- rattling 460
- current 460 rebuild, if it were your engine
- Warm Idle Problem
- Help - Vacuum hookup for distributor advance
- 460 roller block info
- 400 to 460 parts interchange
- symptoms of incorrect power valve
- 73 High Boy Swapout
- Dual plane intake to carb gasket
- D6VE-A2A w/ thermactor and motor build
- 460 Smog in CA?
- Just picked up a 97 F250
- 514 Build plan
- 87 460 vacuum line broke
- 88 F250 fuel problem
