- Backfire on startup- no oil everywhere
- 460 balance issue - need your opinions
- Need 460 build help
- Exhaust Manifold leak - Rh side
- Choke Setting Issues or ??
- 460 EFI Ultimate Build
- 88 f350 7.5 460, fuel injectors #2,3,6,7 are not working
- codes
- 460 Hard Start
- 460 cooling system problems
- 460 hp and torque numbers??
- comp ratio
- Learning about the 460ci?
- comp ratio help
- timing curvage
- best buy ever
- Electrical Issue.
- INTAKE FOR 557ci ?????
- value of a .040 bored d1ve block
- edelbrock or holly carb help
- 460 + TKO 600 trans - which starter to use without solenoid on starter?
- 1991 460 Engine Specs
- first build and lots of ?s
- 460 with roller rockers?
- 460 best cruising rpm?
- Push Rod Length Question
- photos
- 460 rule
- 429/460 heads Question
- my toy
