- Timing Chain cover off '80 460 casting stamp reads 72 Lincoln??
- stoopid bracket
- 460 build up.ideas?
- Crank sleeve?
- Porting D3's
- what is it
- Missing/stalling out issue
- Really need some exhaust system help on a 97 f-250
- .007 over stnd bore, is it time to bore the block?
- Engine underwater...
- '73 lincoln 460 fan vs truck fan
- exhaust question/problem
- 1.25" Crank Pilot Hole
- 460 Question
- rebuild damage estimate advice
- Distributor Issues
- timing proplems
- beat by a toyota!!!!!
- first mileage calc 89 f250
- Looking to build a wild 460 need advice
- help timing chain install
- broken head bolt
- How restrictive are the stock exhaust manifolds?
- converting efi to carb how to
- Why did they do this?
- Stroker for my toy... A couple questions.
- crack question
- carb vs sdfi pros/cons
- c8ve-e
- 88 F250 460 Tune Up Parts Questions
