- 460 EFI Heads??
- 1978 F150 460 timing set
- Fuel Pump Eccentric
- Gettin' my 466 back!
- Kinda Disapointed
- Help Help Help I need a pulley.
- Serp. Belt. Tension Needed--'97 F-250/460
- hard start when hot
- Ford 460 & Lincoln 460
- ARP Oil Pump Drive Shaft, length issues?
- 460 Swap into 77 F-150 complete, or at least running
- mpg f250 4X4 7.5 C6?
- Stuck engine
- 460 belt squeal
- 86' F-250 with 460 dies when warm
- Air pumps suck!!!
- Carburetor Gas Mileage Questions
- Any benefits to using a PCV valve?
- question about the 370
- Powah
- running bad and not at all at times
- 460 vacuum setup and other parts
- 460 getting tired?
- Compression guage
- Difference between a 429 and a 429 industrial motor?
- intake ?
- need inatke 89 460
- 460 which distributor to use?
- 460 total ignition timing advance?
- big compression
