- 460 EFI question
- Should I swap to a 460??
- 429 big truck motor
- cam selections
- Are shorty headers even worth it under 4k rpm's?
- Mallory module update
- Hp for tuned 460
- Blow-by Blues
- Help??? Sheering distributor gear pins
- any info?
- What are these
- 460 Power
- Vacuum lines
- Pushrods and Rockers
- tire roasting 429 build
- lost oil pressure
- Bad 460 block causing cam failure?
- MAF Conversion
- Intake manifold Bolt pattern
- engine mounts?
- Oil Pressure Issues
- 460 burning oil in #4
- 1979 f-600 needs help
- 460 much cleaner inside than out...
- FI 460 in a 75 f250
- 1995 460 F/I parts wanted
- Stuck Distributor
- Ticking at start, sometimes
- 38" tires, 4.10's: Is overdrive worth it?
- 73 460 and C6?
