- best plug wires 97 460
- 460 gas?
- 460 engine upgrades
- Mass air EFI motor?
- 370 engine PLEASE HELP
- Gas/propane 460 question
- Header gasket material for 460 header owners
- 460 EFI / DIS Conversion
- cams, cam gears, and timing chains?
- 460 emission solution?
- 460 problems of the 70's?
- 460 vs. 460?
- 89 f350 460 fixin' to build
- too much vac advance
- Dove head's worth?
- Not enough vaccum advace? cam? timing? advance sprg?
- 460 carb
- 429, did I mess it up?
- Flex Fan for a 460 what do you think good/bad
- Check engine light with codes
- connecting rods
- Need '86 460 advice... (long post)
- Serpentine belt set up.
- hi
- 460 oil leak
- The strangest thing.....
- 429 General Engine specs
- Affordable Upgrades?
- 460 Filled Crankcase with Gasoline
- 429 pushrod length?
