- How much will I end up spending to put flat top pistons in my engine?
- Help with starter wiring
- Will exhaust porting lessen torque?
- Porting exhaust manifords?
- 460 Oil Consumption
- C9VE heads on a '77 460
- Harmonic Dampener slipage
- heat sheild for starter?
- D2VE 429 heads
- 2Y vs. 2YABC
- internally or externally balanced
- backfire threw carb???
- distributor bolt size?
- 97 460cid, horse power range
- 460 cylinder taper tolerance
- bad milage
- stealth 8012 or 8021 best suited?
- Dooe manifold ?
- Carburator Bonnet?
- Roller Rockers for DOVE heads
- Super Cobra Jet head ??
- no gas or what
- Cleaning up intake manifold
- 770 cfm or 870 cfm carb on a 429
- I need a water pump for a '69 429
- sorry for the lie, its my bad
- 460 ignition problems please help!!
- performer intake/lunati 00096 cam???
- engine swap 390 to 460
- 460 engine disasembly?
