- 460 surging after braking
- 460 tune up?
- D5xx-a2a
- Compression Testing and Results
- Best brand of bearings?
- Transmission Help
- What carb is better?
- What size is this
- 97 F350 460 Overheating Post-Research Questions
- Vids of my 528 in action
- total timing
- Interceptor/cobra jet motor
- How does this 460 torque build look?
- Help needed to put on tach to 97 460 CID
- I need help.
- Fabbing a new intake for a fuelie 460?
- Vapor Lock?
- Ceramic coatings ? and compression?
- swapping timing covers
- Air Filter question on 460
- How much can I mill the heads
- F-350 1/4 times?
- Timing Curve and Cam Selection?
- 429 identification
- stealth small or large
- Hp numbers
- Cracked DOVE A Block$#?&*(!
- early timing gear swap
- early 80's 460
- Adjjusting valves
