- 429 fuel injection kit?
- 429 BB Carb Help
- need help with engine ID, tried search with no luck
- Swap for EFI Intake? + Bonus Material
- 1986 460 mods
- Another 460 build??
- Cam Curiosities...
- Oil in Coolant? 92 460
- 460 EFI build
- 429 rebuild ?
- found brain
- Which is better, D0VE block or C8VE ?.
- Need brains..
- 460 and C6 Q's B4 I purchase the parts truck
- estimated numbers?
- Need Cam spec selection guidance
- Building up a 460
- MotorHome not starting
- 77 460 coolant temp switch?
- 460 abd 5 speed help?
- Intake ?'s Dove CJ SCJ Boss?
- 94 460 how do you test the PCM
- 460 Mud Runner
- Crank case venting
- 460 build up E7TE
- F350 460 MPG and gauge problem?
- 460 coil resistance numbers
- Engine blow by help
- 429 Build Recommendations
- dove-c question
