- 429/460 the differences
- Timing Cover Removel
- Exhaust/Header gaskets
- New distributer
- '94 460efi - how do I verify its in closed loop?
- 460 bellhousing
- New oil pump
- Boss 9 anyone?
- 460 injector size?
- 460 head gaskets
- No oil pressure on startup leads to cut bearings(pics posted)
- advancing timing?
- 460 block and head numbers
- P51 Kaase heads + Ford Racing 514 cam=?
- What Carb do I have ?
- 460 efi - how do you get it to idle down?
- carb to injected?
- Just a couple questions about the big daddy ford 460
- Industrial 460 tune up specs
- how much cam?
- 7.5 Intake alterations
- I need the procedure for setting timeing on 460efi
- RV Pulling with 7.5L F250 Regular cab 4x4
- high nickel
- Ok I have had issue after issue...is this possible?
- Hydraulic Roller Cam & Lifters for 460
- 460 life
- 429 Truck manifolds
- blowers
- 460 crankcase breathers?
