- 532 rod bearing issues still
- 460 serpentine belts question
- Engine Blowby?
- how to retard timing
- Yay... Oil pressure issues, again....
- mild 460
- 460 Flexplate Question
- Suggest a stroker kit for my '70 429 (d0ve-c heads)
- F700 & f600 enegine swap?370 swap to 391 will it work?
- Oil Pan Blues
- Need help Guy with Project
- 460 id
- Throttle and Kickdown Linkage
- How do you know if the mechanical gauge is bad?
- Stalling while driving
- 514 coolant leak
- 429 casting #s
- Looking at 460, couple questions
- Pro comp heads truth
- strange 460 prob
- 460 flex plate installation
- 95 F-250 w/460 stumbling
- Where do you run the neg. battery ground?
- first time compression test question.
- First time fire up - timing issue
- '79 460 compression ratio
- Fram Filters
- 429 or 460
- 1985 F350 4x4 460cid Aftermarket HEI installation
- Pressure checking my 460
