- 460 tuning differences yr to yr
- 460 Runs Poor in Hot weather/hot temps under hood
- cooling problem need ideas
- 93 f-250 460
- Better Cold Running 521
- Electrical Issue HELP!!!
- Replaced Distributor now no spark
- f600 370 lima 460 question
- 1973 460 electronic ignition problems
- 460 starting problems still..... help!!
- Fuel injecting a 70's 460
- Cannot stop this water leak on 460!!
- Can a 460 use a 390 flywheel?
- 460 Air injection tube block off
- 460 speed swap?
- what headers??
- low oil pressure??? 460 help!
- 460 information???
- 460 mods?
- 460 initial start up = super rich exhaust & bad trans leak
- duraspark dist mod
- 1983 F-600 370--have some questions
- 460 Cam choice
- How bad is rust on the 1994 F350 supercab 7.5L
- 460 engine spec's
- 460 timing problem
- Rebuilt 460 w/ mild mods from stock...need a little help
- cooling question???
- ProComp Aluminum Heads on Ebay
- 557ci Cam Range ?????
