- Clutch installatoin on the 300
- Power problems
- 300-6 Heads?
- Carb direction on an OFFY DP
- slight issues
- Oil pan/pump removal
- 96 econoline 350 crap mileage and runs rich
- Manifold heat riser
- dwindling oil pressure
- Think the 4.9 can handle this?
- ford straight 6 info
- Rebuild an inline-6 instead of a V8?!
- "Vapor Lock" in 85 degree weather, what's up?
- i had a crazy afternoon
- Edlebrock Carb--anyone use one?
- EFI front/rear exhaust manifolds can I swap them...
- Gearz builds 292 I6
- new muffler
- Got my EFI exhaust manifolds
- quadrajet link
- MSD ignition
- tuning help
- oil type and pressure
- What should water temp difference be...
- dual two barrel carbs
- Engine and Settings Help!
- Check this monster out!!!
- EFI or carbureted?
- Audio Tach
- Timing issue
