- Might be having to make a colorado run, ? about carburetors at altitude
- Removal of smog system
- shift points...
- Rear axle change, level of effort, cost, advice?
- One more time on timing...
- Burning Alt. bearings with shorter belt, maybe?
- When you use a truck like a truck
- 4.9 exhaust
- FI 4.9 ? revisited
- Alternator and battery
- throttle body spacer?
- DSII Just plugs in ?
- The 300 I6 is awesome! How can i make it better?
- Finally got my very own Ford!
- need help on power gains
- Intake Air/Exhaust Manifold Preheat Shroud
- Question on EFI manifolds
- Spark Plugs
- another question about headers for a 95
- Can the 300 be built torquey
- carburetor ?
- Old motor.....want to get it running
- 300 runs really rough
- Help, Weird Starting Problem.
- what rims
- f-150 backfires
- Bigger injectors?
- Pushrod Spin?
- Swapping 78 with carb and 3 speed manual to 87 with EFI and auto overdrive
- NEED HELP not getting any spark
