- aggravating stumble
- engine codes
- 84 300 Distributor with TFI-IV Timing Problem
- Oil burning at start-up
- Will an electric fan give me more horse power?
- My 4x4 Inline Six!! For sale?
- Does fuel injector cleaner do anything????
- robbed power in a 300
- Changing gear ratio?
- mods
- rubbing alcohol will help pass E-check?
- 1bbl carb (carter I think) screw identification
- Just ordered the Blue Racer 270-2H Camshaft!
- Rear main
- Noise, sounds like coming from rear end. What do I do?
- Crew Cab 300
- I lost my idle screw on my 300 straight six.... I need a replacement
- What is a MSD-6A??
- is 15W-40 too heavy of an oil for my 300 I6?
- Tune-up guide?
- Tune up tips?
- how to pre-load lifters?
- 300 to 351 swap pros and cons
- K&N on 4.9?
- carb off 78 is different from my 79. Will it work??
- Codes?
- Stalls after startup
- Can I convert my 83 Carb to 88 MPI?
- Will a C6 bolt up?
- high performance parts for the 3oo inl6
