- Jacobs Ignition
- HELP ASAP!!! Cam gear removal
- Towing with I-6, need more oomph!
- 85 f150 4.9L I6 carb problems.
- 300ci to 460ci swap
- miss at idle
- Funny story and bouncing engine
- tune up and stalling...
- What weight oil do you use in your 300?
- 85, 4.9 l engine shuts down
- Turbo - Revisited
- 300 I6 Vs. 390 in towing
- Question about high volume oil pump
- Broncos with 4.9L
- Replacing timing gears
- Engine Running Badly
- when points go bad......
- help!! truck broken, wife angry
- How'd they do it?
- 300 I6 makeing noise after I turn it off
- horrible gas mileage...89 4.9L I6
- GAS Line Sludge
- more carb and exhaust popping
- 300 EFI SMOKING OKAY OR NOT OKAY?
- throttle bodies, cold air kits, homemade mods?!?
- Update on EGR bypass
- no smog control equiptment help
- EGR location
- Pure Oxygen intake?
- clutch
