- '81 4.9L 300ci Squeaky Valve Train
- Update ignition or not?!!!?!!?!?!?!?!
- My First motor swap :-)
- won't start somtimes
- look at this spark!
- fuel injectors
- Need help daily driver down
- manual transmission cooling
- Inline Six History
- Should I build up my 300?
- Squeaky Valve Train 4.9L 300
- 300 in a 1953 F1
- manual trans swapping question
- fastest
- milling the head
- Exhaust Manifolds
- Failed State Emissions Inspection !!! Doh!!!
- :confused: Compression??? :confused:
- what rear end?
- Anyone Figure this one out?
- best exhaust?
- Oxygen Sensor?
- Oil pressure problem please help
- rear end gears
- What's your timing set at?
- Whats the best fuel milage a 300 can get?
- 2bbl adapter for 1bbl
- F-150 I6 won't turn over
- is this ok
- Side Cover Gasket?
