- engine runs better with egr vac line removed and sensor unplugged
- Can you put a 2 barrel on on 300 6
- Egr Tube and Vacuum Line..
- '78 high amp alternator
- Time to rebuild
- lookin for a locker
- exhaust selection questions
- 200ci I6
- 300 grunt
- MSD6a box
- recommend machine work 4 rebuild
- Ever put a Bronco tank in rear of '96 F150?
- oil change
- Summit Exhaust Systems
- Anyone Know good machine shop (specializing in Ford 300)
- i have code numbers and need to know what part to change
- Questions about Feedback Carb setup
- How was this engine in 1-tons?
- clifford performance intake and header
- Radiator/fan Choice
- random questions
- coolant-heated carb spacer
- which pistons?
- Water acces on 4.9liter head....3/8ths pipe?
- ECM locator
- Is it Worth It?
- I6 trans/t-case combos
- Reset original milage on replaced cluster
- efi truck to carb
- 4.9y to 4.9z?
