- Looking for a 2bbl adaptor
- Rough Idle when cold
- head swap and boost#?
- Distributer gear stripping out
- grinding sound from the oil pan...
- Lifter Noise or Piston Slap ????
- need thermostat help!
- Minor upgrades...
- Cam Specs ??
- fun on the "cruisin" drag...
- screw in rocker arm studs
- Where to buy Cam/Lifters ?
- exhaust, crackling and backfiring
- sensor location on block for gauges
- Uhh...Stupid Newbie Question...
- E4OD to ZF5, Possible?
- Straight 6, 1968 shorbed ford pick. here are some pics, is this a good engine?
- Question about exhast/2 barrel for 300!
- inline six performance
- Fuel pump cover plate?
- Carbed EFI Intake
- Rough Running at mid speeds
- Having ignition problems ? CHeck this out --> TFI Module Litigation Settlement
- 300ci Durability ? How many miles on a stock engine ??
- does 94 4.9 use a harmonic balancer?
- water injection and the EGR...
- Engine Flush ??
- smog exempt what sould go?
- Stright six gas mileage?
- Rough start
