- Exhaust swap = performance
- What a miss
- 6 or 8
- Detailed help (carb/distri conversion)
- Questions on how to set timing
- rad cap is cold????
- EGR restrictor plate?
- Studs on exhaust manifold
- 223 Solid or Hyd. Lifters
- pulling a inline six
- I6 in the 14s?
- 223 I6 Parts
- My E-fan setup.
- What month?
- Question about timing chains and other problems!
- Restrictor plate
- replacing e4od with aod...what do i need???
- Throttle cable set up with a 4bbl
- Restore* engine restorer&lube w/CSL???
- Offy DP Intake and Auto Transmission Kickdown
- Check this out Inline enthusiasts
- Exhaust Manifold Qeustion
- 86 F150 stalls when making sharp turns
- 223 intake gasket. rings needed?
- Crank ???
- 300 hard to start after shut off?
- Oil pressure doesnt make sense?
- Carb part # question
- Wierd One - Fuel System
- 96 still won't start
