- which is better?
- any tried additives to reduce smoke?
- a new personal record (lifter wear)
- thread about exhaust with a performance twist
- Missing Carb Ports
- The plug won't budge!!
- 300 c.i. Questions
- '64 pickup
- Head rebuild
- Starter Solenoid Hook-up
- Port/polish stock throttle body
- EGR removal from 83 4.9
- 289 and 300 fans
- 84 4.9 commercial look at mpg
- Fan Clutch removal?
- Setting the Timing 4.9L EFI?
- Fuel Pump problem
- 300 six motor swap
- alumaloy
- How heavy is an Inline 6
- K&N air filter for 300 6 cyl??
- Opti's crack at a larger TB and intake porting
- heads
- exhuast/back pressure
- Venom 400 for I6 300
- 93 6cyl miss?
- High lift valve springs
- number one hole is down
- efi intake manifold, couple ?'s
- new 4.9 owner please help
