- Spark comes and goes????
- 1-bbl carb question
- 85 emissions problems
- Headers work on a 4x4 or not
- Re-Calibrating the Speedometer.....effects on PCM ???
- engine swap
- Dyno numbers
- Losing Oil Pressure?
- Our six bit the dust...
- Oil pressure on my old 300
- Trick to removing echaust manifold studs?
- Truck Accelerates on it's own when in nuetral or inbetween gears.
- Timing Excitement
- What gear drive?
- X Factor
- Question on sale of my truck
- gotta love the torque
- Finned valve cover?
- Odd and annoying idle/part throttle issue...
- 300 I-6 and a T-98
- Wanting to die on startup.
- Looking for the $75 clutch and flywheel
- $10.00 300-6?!
- Carburators
- Electric fuel pump on Carborated 300-6
- Intake to Head bolted joint
- Adjustable fuel pressure regulator
- Mazda Tranny Grinding in 3rd
- Gave up at 144,000
- Low oil pressure
