- Cam selection
- Air injection into head
- Carb question
- OBD code P0141
- STAGE 8 header locks
- Should i keep the six or go 351w
- distributor noise?
- the baddest 300 around (flames)
- Total timing
- Valve cover
- Engine death
- Upside down fuel pump???!
- Oil Issues 95 F150
- Drag truck with big six or v8?
- ac compressor bypass
- New Engine 2 issues
- M5R2/M5OD trans/bellhousing overall dimension
- oil pressure problem need help?
- Radiator 3 or 2 core
- 1988 4.9 Knock Sensor
- O2 sensors I6 4.9
- Swapping to an automatic do I need to pull the pilot bearing?
- Gotta complain about the YFA
- 300 block changes
- big block 6 stump puller
- Valve Adjustment
- Block ID
- ? for those of you with a 4 barrel set up
- Why do I have all the best luck?
- Looking to buy F150 w/ 300/5 spd need opinions
