- flywheel question
- She dont like when it rains. (ignition/electronic problem?)
- Pulling my oil pan tomorrow
- air management circuit 1 failure
- EFI mani in '79, Raven muffler?
- 300 misfires at idle / moderate pinging under load
- random stalling
- starting problems
- Maximum power Minimum money
- help, new engine, no oil pressure
- side cover help
- last year of the i6
- is this a good exhaust?
- Chronic high idle problem - finally fixed it
- Power
- timing
- mpg, just wanted to share tips
- Smog Pump maintenance
- Engine missing when at cruising speed?
- 300six enough to turn over 35"s on stock gears?
- Compression Pressures
- 300 efi into 79
- Are 300 sixes good pulling motors?
- np435 behind a 250?
- mpg?
- Carb specs
- What grade fuel?
- Got a question
- rebuild for ponys
- red hot exhaust
