- 2BBL on 1BBL manifold.
- Cam install worth the hassle?
- phenolic cam gear failure
- Curb weights?
- TFI silicone
- Funny Clicking Sound
- Budget Rebuild 300
- battery ground
- Help withCarter YF (Video)
- something with 89 F150 4.9L it would stumble when hit gas pedal full
- 1989 F-150, 4.9L MAF Conversion
- Pre Oiling engine
- What engine is a direct swap?
- Ignition choice
- need help
- Possible broken timing gears
- Cylinder head pics, might find useful...
- $1500 Budget Rebuild
- Crankshaft?
- Water Heated Spacer Question
- Stalling problem on an '89 F150
- Piston selection--300 build up?
- Some 200 questions.
- header back dual exhaust kit?
- broken intake manifolds
- Q-jet carb on a 240
- Carter YF
- 300 I6 fuel delivery issue
- 300 I6 has a hitch in her giddy-up...
- How to replace freeze plug with freeze plug heater? It for 79 F150
